TwinTurbo.NET: Nissan 300ZX forum - my "door open" light keeps flashing even though
Dark Angel Z
on July 06, 2005 at 12:59 PM
anyone have a problem/issue with the Z they just cant solve?
posted by PakiHomBoy
on July 06, 2005 at 12:32 PM
the doors and hatch are tightly closed. i have no clue what it is.
PakiHomBoy
12:32:20 07/06/05
My z has started several small fires
Joe(NoVA)
12:39:45 07/06/05
lol, thanks for the laugh, i needed that (n/m)
PakiHomBoy
12:42:22 07/06/05
stalling when the car's moving and I press the clutch
ZEngineer
12:47:37 07/06/05
http://xrl.us/hesitation
E=mz²
13:09:10 07/06/05
again, cardomain users should cease giving advice (n/m)
genic
13:16:18 07/06/05
when I installed my JWT chip and Fidenza flywheel
CRAZZEPETE.
13:26:51 07/06/05
no, not quite
ZEngineer
13:42:24 07/06/05
Have you tried getting some real filters..
spicyZ
14:14:57 07/06/05
Mine seems to have mysteriously fixed itself.
TT XTZ
13:39:57 07/06/05
Your blow-off valves are adjusted open too far.
Dustin
17:59:38 07/06/05
i think my car has some interior squeaks
RedSER13
12:48:39 07/06/05
squeaky hatch can be an easy fix
ZEngineer
12:50:14 07/06/05
My Z hesitates sporadically without any rhyme or reason...
BondzTT
12:49:32 07/06/05
start with a strait/level car (n/m)
JDMz32smity
12:57:54 07/06/05
it has been doing it ever since I bought the car (n/m)
BondzTT
12:59:49 07/06/05
You 2 sound like you had the problem I had....
TonyD(90Z32TT)
14:40:08 07/06/05
Big 2nd...mine too...not all the time but..
stewZ96NA
13:00:04 07/06/05
yep between 2-3k rpms for me too. (n/m)
BondzTT
13:02:30 07/06/05
That's about what mine was like...
300Zach
14:52:31 07/06/05
E=mz²
13:05:36 07/06/05
my "door open" light keeps flashing even though -
Dark Angel Z
12:59:27 07/06/05
my brake light comes on EVERY time i brake
PakiHomBoy
13:07:11 07/06/05
remove bulb from the cluster or replace brake sensor
E=mz²
13:10:52 07/06/05
yeah, it's really annoying. especially cuz it makes a slight
Dark Angel Z
13:11:53 07/06/05
I had to remove the bulb because I have an LED brake light
ZEngineer
13:15:18 07/06/05
the ECU has no connections to the brake lights
spyhunter(nj)
13:24:18 07/06/05
caught me on a technicality, but you get the picture =) (n/m)
ZEngineer
13:25:40 07/06/05
may be hood switch. worse case remove the bulb from
E=mz²
13:07:21 07/06/05
sure do... ive had this problem for over a year now....
sethkins88
13:00:20 07/06/05
loose vaccum line? (n/m)
E=mz²
13:07:58 07/06/05
would it only hiss when its the car is warm? (n/m)
sethkins88
13:11:57 07/06/05
my best guess:
ZEngineer
13:24:27 07/06/05
thanks man (n/m)
sethkins88
13:40:51 07/06/05
sethkins88
13:39:28 07/06/05
Got a minor one in my drivers door/window. If the driver
Zirvana
13:02:21 07/06/05
i have that problem also!
PakiHomBoy
13:04:35 07/06/05
Probably just some slop in the linkage somewhere. My
Zirvana
13:07:42 07/06/05
I have that problem as well (n/m)
mickleson(oh)
13:17:39 07/06/05
When my Z gets hot, runs like a HD, runs on 5 cylinders
JERRY
13:03:24 07/06/05
A coil that is starting to fail will show first when hot >
my91z
13:33:27 07/06/05
Been there done that same result, maybe multiple coils? (n/m)
JERRY
13:56:19 07/06/05
i have a freaking rattle in my dashboard, i have taken
E=mz²
13:03:56 07/06/05
Once again 2nd...my solution...
stewZ96NA
13:07:41 07/06/05
My windshield wiper fluid leaks...or somethign
SimplyZ(MD)
13:04:33 07/06/05
I have that same problem. I just disconnected the
longhornz32(Dallas)
13:08:48 07/06/05
PakiHomBoy
13:09:59 07/06/05
You need to replace your brake relay w. a TT one to
YugoBernie (NoVA)
13:22:40 07/06/05
thanks, will look into it (n/m)
PakiHomBoy
16:49:36 07/06/05
If washer fluid leaks from nozzle's on hood...you need new
Zirvana
13:31:26 07/06/05
It seems like it'll leak without using the fluid
SimplyZ(MD)
13:41:20 07/06/05
Normally, the restrictors keep the fluid from coming out
Zirvana
13:44:47 07/06/05
i havent noticed that problem, but i'll still look at
SimplyZ(MD)
14:04:19 07/06/05
Don't know???? (n/m)
Zirvana
14:15:17 07/06/05
Stereo system made my hatch rattle worse.:) (n/m)
CLOWNSHUE
17:21:24 07/06/05
Oh yeah
mickleson(oh)
13:14:27 07/06/05
my Z is a slut...
apudapus
13:14:40 07/06/05
but her being so hot makes it all OK =) (n/m)
ZEngineer
13:19:20 07/06/05
hey, are your turn signals smoked? i can't really tell from
Dark Angel Z
14:32:34 07/06/05
yeah, 'cause they're JSPEC (JSPEC front) (n/m)
apudapus
00:15:46 07/07/05
"I'm not bad; I'm just drawn that way." (n/m)
TT XTZ
16:39:19 07/06/05
I have a fuel pressure problem
Fuzznutz
14:50:50 07/06/05
My T-Tops creak. (n/m)
zgene4
15:06:58 07/06/05
I have a detonation sensor problem.
WickedZX (NoVA)
15:36:52 07/06/05
Detonation "sensor" problem? Sounds like detonation problem
spicyZ
15:54:37 07/06/05
Well maybe my gauge is off a bit.
WickedZX (NoVA)
16:08:06 07/06/05
Um - you're detonating and then going into saftey boost. (n/m)
YugoBernie (NoVA)
16:46:49 07/06/05
Alright then, definitely need to fix that.
WickedZX (NoVA)
00:22:55 07/07/05
I would advise that you turn down the boost or get a
YugoBernie (NoVA)
11:23:32 07/07/05
It might be reading low.
SactoTodd
16:58:03 07/06/05
cruise control...
CLOWNSHUE
15:44:34 07/06/05
